Fallout 3
Publisher: Bethesda
Fallout 3 is the revival of Interplay’s excellent
Fallout series of games following many years out of the limelight. It’s developed and published by Bethesda and, judging by the success of the game, we’ll be seeing more
Fallout games in the future.
Despite using the
Oblivion engine which is now a few years old, the game looks absolutely stunning. Bethesda has spiced up the graphics a bit since
Oblivion and has extended the engine – there are some great explosions, soft shadows and smoke effects that are particularly noteworthy.
We tested the game by manually playing a section of the game that incorporates a number of explosions and effects that you’re likely to experience during your time in post-apocalyptic Washington DC. We recorded the frame rate using FRAPS.
The in-game details were set to their highest values and both anti-aliasing and anisotropic filtering were controlled by the application settings instead of through the driver control panel. This meant that transparency anti-aliasing was enabled, along with HDR and all of the cool smoke effects.
Fallout 3’s engine is by default capped to 60 frames per second, which can make benchmark results very unclear, especially when testing at lower resolutions or with high end graphics cards. To remove the 60FPS cap you’ll need to find the Fallout3.ini file in \Documents\My Games\Fallout3 and edit the file so that iPresentInterval=0. This removes the frame rate cap, and allows us to get a much better idea of a card’s abilities.
ATI Radeon HD 4870 X2 2GB
ATI Radeon HD 4850 X2 2GB
Gainward Radeon HD 4870 1GB GS
ATI Radeon HD 4870 1GB
Nvidia GeForce GTX 280 1GB
Nvidia Geforce GTX 260+ 896MB
Nvidia Geforce 9800 GTX+ 512MB
ATI Radeon HD 4870 512MB
ATI Radeon HD 4850 512MB
Frames per second
Frames per second
Frames per second
Frames per second
Frames per second
Frames per second
Frames per second
Frames per second
Fallout 3 is a relatively new arrival to our test systems, and with the frame rate cap removed shows an advantage to ATI/AMD for average frame rates, but has Nvidia's card delivering a smoother gameplay experience with higher minimum frame rates. Once again we see the Gainward HD 4870 Golden Sample post only marginal performance improvements of just fractions of a frame per second over the stock 4870 1GB thanks to it's conservative 3.3 percent core overclock.
